150psi compression test - all 4 cylinders
    Is this normal?
    i see some thread people have 175->190psi
    is it because of different elevation?
    Originally posted by XcluziveAZN View Post
    Is this normal?
    DID you crank the motor over with the throttle open?
    If not do it again. 150 is not good at allllll.
    750 WHP/575 TQ CD5 Raping a street near you....
    realHomeMadeTurbo.com / Kaizenspeed.com / LSD Motorsports / Tempest Racing /SpeedFactory /ExplicitSpeedPerformance
    GFI HOLLA!!!!!!
    http://www.youtube.com/watch?v=Cdiz0k0Rudw
      The gauge could be inaccurate. I would be more worried if one of cylinder is way off than the rest.
      Use the same gauge on many cars and see what kind of numbers you will get.
      A&P-IA
        OOP. I did not have the throttle open.
        I will try it again
          wrong
          Theres a MUCH easier way... guesses anyone?
          GFI HOLLA!!!!!!
            it's not about what the numbers are, it's about consistency. there's too many variables for exact numbers.
            150 on all four is fine.
              Wed3k is right. The consistency is the key but if you are worried about the "low" psi then Accord's compression is normal when it's between 9,3-12,3 bar (135-178psi). And i'm not saying that 190psi is not good but those are basicly the boundaries.
                Thank you for all the reply
                I learn something new today
                  Originally posted by Supergenius View Post
                  wrong
                  I am wondering what's wrong about my post.
                  I am sure there are other ways to certify the gauge set he is using. Like other posters say, to me, having 150 psi on all cylinders is not really the problem but one or two are off by more than 10% is something to think about.
                  A&P-IA
                    Still... 150 indicates there is something really wrong. should be up around 180-185 id think. AND within 10 or so
                    GFI HOLLA!!!!!!
                      I wonder what kind of numbers the OP will get with Wide Open Throttle.
                      A&P-IA
                        all gauges are different and there's too many variables including battery health and cranking amps.
                          wrong
                          So, what is easier way?
                          A&P-IA
                            I've also been told to test compression when your engine has been brought up to operating temp. This allows for proper expansion of rings etc.
                            Maybe it doesn't matter all that much, but that's how I do it.
                            http://www.cb7tuner.com/vbb/showthre...=1#post1823428
                            My Custom BB6 Dash Swap Thread
                              That's how you should do, in my book.
                              A&P-IA
