Idle problems Still...
    I can't get one of the screws out because its stripped. So im guessing the owner before me had this problem previously. what im going to do is try to find a tiny ass vicegrip and pull that sucker out. hopefully the FITV solves the problem.
      Also, do you have any air bubbles in your cooling system?
      And how new are your spark plugs and wires? Cap and rotor?
      MRT
        The first thing i checked before everything else was my cooling system. there was no air in it. Hadn't checked my spark plugs, but i did clean out my distributor cap because there was some corrosion. I havn't bleed my cooling system since i cleaned my iacv. but it ive been driving it about 20 miles to school and 20 miles back with no overheating. just the idle.
          We removed the whole FITV assembly, and man was it a pain in the ass to take off. i cleaned it with carb/choke cleaner and i backed it all the way down till it was snug. i put it back on and made sure all the bolts to it were tight and had a good seal. Im still having my idling problem. should i bleed my cooling system agian since i removed everything, air got into the system agian possibly?
            yes anytime you open lines for the cooling system you need to bleed the cooling system.
              If the vise grip wont work they also make a bit for a drill that will remove stripped screws, I believe craftsman makes one, there are some other companies as well.
