tranny problem
    tranny problem
    so i was driving to work one day and i went to make a right turn and was down shifting and i could not get my car to go in any gear but 5th and reverse. after that i was banging the shifter in every direction to try and get my car to go into any gear. while this was going on i had the clutch pushed all the way in. then i heard a loud metallic bang and my tranny locked up. then magically it all worked again and i was able to drive away. so i am happy that my car is still running and that i am not replacing my tranny but what happened and how should i try to prevent it???
    How old is your clutch?
      I guess the shift linkage.
      But it's just that, a guess
      MRT
      sneaky motherfucker
        this is how i dx probs w/ my ride. over simplify!
        ex. car wont shift... what shifts car? = Clutch what moves clutch = clutch master & slave... what moves mstr & slave = pedal/hydraulic fluid/pressure. check for leaks. adjust pedal. bleed lines.
          the clutch is not that old but it wouldn't surprise me if its going bad with how i drive but while this was happening the clutch was never engaged and my engine never killed it kept idling
            Did the bang sound like it came from inside the trany or right under your shifter?
              Inside the tranny for sure
