Started up fine with no proplem drove it out of the neighborhood and got about a mile down the road and it cut off. Started it back up for a second and it died again. After that i checked all of the connections and wires, Lastnight i replaced the distributor cap and rotor, that is fine triple checked everything. Novemeber 21st i bought and replaced the Ignitor and it ran SO good. I got a ride from a friend to the parts store and exchanged the few weeks old ignitor one for a brand new one and it still wouldnt start. I tried 2 different times to jump it off. Still no start. I can hear my fuel pump turn on, my battery isnt dead, i have half a tank of gas.. Someone please help me out here ive replaced and cleaned and fixed so much stuff on this car and i still have problems with it..
Car Died On The Side Of The Road
you don't have to replace the main relay. You can simply resolder all the contacts and it'll be as good as new. They crack when they get old and can lose connectivity sometimes over bumps.
Try drilling holes in the casing when you have it out to keep it cooler when its installed back in the dash.
Originally posted by Losiracer2 View Postyou don't have to replace the main relay. You can simply resolder all the contacts and it'll be as good as new. They crack when they get old and can lose connectivity sometimes over bumps.
Originally posted by BLUBB2 View PostCheck for spark via at the spark plug...If that checks out, check for fuel. Hopefully the timing belt didnt break..Also could be a ground issue.
Originally posted by JDM_CB7_TX View PostThe main relay powers multiple things.... I think you need to change the main relay as it is not extremly exspensive at all and then check for a spark issue.
Originally posted by wed3k View Postbut he hears fuel pump which means the main relay is delivering B+ to the pump.
what kind of ignitors are you putting in? id only recommend oem.Last edited by evil_demon_01; 12-07-2010, 04:25 AM.
Coil or ignition switch.
Edit - If you use the green + icon beside the "Quote" button you can multiquote.
Just click the green + on all the posts you want to quote, then click quote on the last one.Last edited by evil_demon_01; 12-07-2010, 04:27 AM.
My 5.7 LS1 Holden Ute
