so its 6:30 am and cold my car was sitting 4 about 14 hours. The car was turning over, but not starting, its tuned up and everything. never did a fuel pump or fuel pressure regulator, it really feels like the fuel pressure isnt strong,and never did injectors? please help car has 270,000, but still runs great!!
very hard start this morning??
Can you smell fuel? If so then it's probably not getting a spark. If you can't smell fuel then try replacing some of those component you listed. Also, your title seems to imply that it did eventually start. Although your description says otherwise.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
did you check fuel pump (main)relay
Destiny Struggles To Reassert The Pattern That Was Meant To Be.
Also Some Of These Members Are Wise Guys With There Wise Guy Answers . Also only inexperienced drivers put donuts in front . You can follow me but it's going to hurt!
I'd say 100% its the main relay. I had this issue back in nov. 06' my car kept cranking and cranking
you can fix it by resoldering all the connections...what happens is they crack over the years due to a combo of heat/age/vibrations
