Ok no oil leaks anywhere on my motor, but when im driving or sitting at a light i am getting burnt oil fumes in the cab of the car, i cant figure it out.. i have also checked for exhaust leaks and it is all tight... what could this be?
burnt oil smell in cab?
Thats strange.Just to be safe, make sure theres still oil in the car! Not to insult your intelligence or sense of smell, are you sure its not an exhaust leak? I know you said you checked the exhaust, but what about the header under hood as well for leaks or cracks?Also, how about a leaking fuel filter or injectors?
If the smell is strong inside the cabin, then internally burning oil wouldn't be a likely cause unless the car is sitting at idle for an extended period of time, or has an exhaust leak (which was already ruled out.) The only way it'd be storng in the cabin while the car was being driven is if it was burning off the outside of the downpipe.
Originally posted by pninja82 View PostThats strange.Just to be safe, make sure theres still oil in the car! Not to insult your intelligence or sense of smell, are you sure its not an exhaust leak? I know you said you checked the exhaust, but what about the header under hood as well for leaks or cracks?Also, how about a leaking fuel filter or injectors?
Originally posted by tonytoka1979 View Postafter driving for a few min then opening the hood to continue my search of the fumes i noticed what looks like small droplets of oil all over the the intake manifold, valve cover, and in between.. anyone else ever experience this? still no visible signs of oil leaks..Better to have and not need , than to need and not have!
Life is simple make choices and don't look back
MRT http://cb7tuner.com/vbb/showthread.php?t=173251
