auto tranny not working!
    ok i bought a 92 accord ex coupe. the guy that i bought it from told me that the tcm was and was the reason for it going in 4th gear when i put it in drive.
    but ive changed the tcm and the solenoids on the tranny and it still does it. what else can cause the problem. and the d4 light is not on.
    well... is your check engine light on? but right off the top of my head. it sounds like a linkage problem.
    "My FOR SALE thread - Click here"
    MEMBERS RIDE
    99 SILVERADO
    WHEEL FLIP
      none of the lights are on and how do i go about checking the linkage....i really know nothing about automatic cars!
        I'd check to see if it's throwing any codes
        MRT
        sneaky motherfucker
          changed the tranny fluid?
            sounds like its time for a new or rebuilt one. if you have changed all the above go to a shop and ask them to take a look at it. make sure again that the TCU is not bad . if you have changed it , look to see if there is any water that can or has got on it. if it smells like burned wires that's a bad thing too. some parts that you buy new can be faulty . good luck.
              i aint got time to do all that! guess im going to sell it!
                Checking the codes takes about 30 seconds. How busy are you?
                MRT
                sneaky motherfucker
                  WOW the lousy information in this thread hurts my head...
                  The D4 light is an indication of a TCU error code. A LOT of people assume that means the TCU is bad, and they waste their money replacing it, only to get the same problem over and over again.
                  The TCU is most likely working properly, and telling you what isn't working.
                  Read the "read this first" thread at the top of this section. Click on the link that tells you how to read the error codes. Follow it. Fix whatever is wrong. Reset the TCU (pull the battery cables for a few minutes). It should work just fine. If not... then your transmission may be shot.
                  And yes, change your fluid, as I'm sure it's long overdue. Most automatics are. Don't do a flush, just a change. Use OEM Honda ATF ONLY... nothing else.
                  The check engine light has nothing to do with the transmission, aside from 2 codes that really only rely on feedback from the transmission to control the engine.... they wouldn't tell why it is doing what is happening here.
                    i took it to advance to check codes nothing came up....so i guess the tranny is just bad!
                      if that D4 light is on, there is a code.
                      Most autoparts store employees are idiots...
                        My d4 light isn't on either! When I took the tcm out and turned the key twice it came on but when I plug it back up it doesn't come on when key is turned twice! So I really don't know what's happening!
                          sorry man but not to be a jerk but if your talking about Advanced auto parts they cannot check your car for any engine light or ( S ) light or anything, our cb's are OBD1 and they don't have a connector for that, more than 99% of autoparts stores only do OBDII
                          and to be honest I have literaly had his exact problem but you'll have to give more info on what your problems are heres a link to the tread i made about my issues with some pics if you think it's the TCU then open it and look inside http://www.cb7tuner.com/vbb/showthre...05#post2676405
                          Calling your USDM Accord "JDM" is like calling President Obama "African".
                            If the old TCU gave the D4 light, and the new one doesn't... the new one may be bad. The old one might be fine. Try swapping back to the old one. Something is definitely wrong with some component for sure (unless the tranmission itself is completely borked.)
                            Did you check your fluid level?
                              Well lets just throw in a special peice of information
                              If the d4 light is FLASHING, if its on solid its obviously working right
