So i compression tested the cylinders and got 200 for the first 2 cylinders and 210 for the last two i know that the max is 178 but its an old tester and is a lil messed up but the place i got the motor from guaranteed it tested and good.
I have pictures of the wires and from both my obd1 wiring harness and my obd2 dizzy which are numbered and im just gonna match up the wires with the same numbers. there are a couple of wires that i dont know what they go to so if neone knows and can help that wuld great
obd1 obd2
CYLP-Orange-2 CYLP-Yellow-2
CYLM-White-1 CYLM-Black-1
TDCP-Orange/Blue-8 TDCP-Green-8
TDCM-White/Blue-4 TDCM-Red-4
CKPP-Blue/Green-3 CKPP-BLue-3
CKPM-Blue/Yellow-5 CKPM-White-5
[/IMG]This is obd1 Wiring harness from car to dizzy obd1
This is the TDC and CKP on the motor
obd1&obd2
Tach-Blue-9
Power-Black/Yellow-10
Ignition input-Yellow/Green-6
[IMG]
[/IMG]This is the obd2 dizzy
This plug comes from the external coil pak
[IMG]
[/IMG]
This is also from wiring harness to dizzy obd1
The ones with ?'s i have no idea where they go..... thanx for help
obd1 obd2
This is the TDC and CKP on the motorobd1&obd2
Tach-Blue-9
[IMG]
This plug comes from the external coil pak[IMG]
[/IMG]This is also from wiring harness to dizzy obd1
