Burnt oil smell
    Burnt oil smell
    Is this bad? My friend and I cleaned the IAC. In the process we removed the PCV valve and he told me my oil smelled burnt. My sense of smell is extremely limited, so I couldn't tell.
    I'm at about 4000 miles since my last oil change. I was hoping to go to March or April, since I'm currently running full synthetic. Should I change, or keep running till 6k?
    Like I said, I'm at 4k, and I'm about halfway between the two marks.
    As long as were on topic. I've always bought Bosch filters, and was considering going to the dealership and buying a handful of filters to last me a while. So, what's your favorite filter?
    MRT
    sneaky motherfucker
    Cant go wrong with a honda geniune oil filter
      I run Zmax, with Castrol Edge 10-30, and a Fram Xtended Guard filter. This filter is specifically made for Full synthetic oils. And i change mine every 6k. No oil leaks, 255k on stock engine, and i rod on it most the time. Just check your fluids frequently and stay on top of things and you should be fine.
      Thats just my 2cents.
      "I'm NOT drunk, I'm avoiding Potholes".
      http://www.cb7tuner.com/vbb/showthread.php?t=174029
      Check out the whip^
        I run Castrol syntec, and I just use a fram filter. I used the same on my tacoma from 20k-230k miles before I sold the truck, and the motor was clean clean.
        350z- Injen CAI & CB, Stillen testpipes & headers, kinetix SSV plenum, TEIN SS coilovers
        90 LX- a6 conversion, 2.5in exhaust
          OEM honda filter. its like 7 bucks and Mobil 1 clean 5k.
          COUPE K24
            Does anybody have any opinion on the burnt oil smell? Change or stay?
            MRT
            sneaky motherfucker
              I say just change the oil if your concerned about it being burnt. Better safe than sorry.
                Oil
                Change the oil and check for leaks. Maybe he was smelling burned oil on the manifold im guessing. Another reason for the smell might be that its time to change the valve. Cheap, Easy, and will run a bit smoother if needing replacement.. my 0.2
                  You will get a burnt oil smell with a engine that has mileage on it. Its perfectly normal. Did you ever wonder why when you change a head gasket your head bolts smell like burnt oil? Same thing with time and heat the oil can coke on metal parts. That is probably your issue. Take the PCV valve spray it with carb and choke cleaner.
                    The PCV valve is new as of October.
                    MRT
                    sneaky motherfucker
                      Maybe you should check to see if the smell is there still. If it is then there could be an alternative problem causing it.
                        Could also be a bad piston ring(s). They tend to go bad on any high mileage engine. Does the car puff and blue smoke out of the exhaust? whether at idle OR at high RPM. At high RPM its just the start but if its at idle, it could be bad and will get worse. That could explain the burnt oil smell.
                        Check out the whip^
