i just found out that bisimoto will not be making his steel rods for the f22 so this puts my build on hold...i was wondering if stock rods could stand up to 200whp with arp bolts?
alternatives to aftermarket rods?
another option is having your stock rods shot peened which increases strength. The stock rods should be able to hand up to 300hp and the f22 usually fails not because of the rods but because of the pistons. The ring lands are weak and are usually the first to go.
member ride thread
DIVULGE MOTORSPORTS
It depends if the power goals are with turbo, or without.
200hp with turbo, the stock rods will be fine. As said above, the ringlands will be the weak spot here.
200hp N/A, you should at the very least upgrade the rod bolts with ARP bolts, as you mentioned. That won't guarantee that it won't break, but it'll at least increase the chances of survival. A high-revving N/A motor puts the rods through hell!
There are other sources for rods, I'm sure. Bisimoto has the best F22 parts around, but if you do your research, you could find something else. I think Probe made F22 rods... not sure if they still do. Not top quality, but for 200hp they should be plenty strong enough as long as you're not planning to rev to 9k like crazy.
Keep in mind there are other options for aftermarket rods, such as Crower and RaceEng. They are more expensive however, but will give you the same piece of mind as Bisimoto, possibly even more. Increasing your budget by an extra 450 or so shouldn't be too much, at the most maybe push you back by about 3-6 months. But I could be assuming too much. Also keep in mind that H23 and B20A5 rods work as well should you find some.'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
Damn
well with my luck probe discontiued their rods....soo., i happened to look on summitracing.com and found carrillo rods for the h23a1, i just wanted to know if these would work fine or not. heres the link: http://www.summitracing.com/parts/CNN-HNH2365581H0/
edit: just found the specs on the stock rods and the ones from probe to match to the carrillo rods and the measurements match up.Last edited by mikecb7LX92; 02-11-2011, 03:47 PM.
