Okk i have a H23a1.. Now i think i know the answer too this question but just wanna make sure im in the process of a rebuild on my h23 and was looking too put these type s pistons in it.. in the research all i got was that they were for h22.. but they can be used in my h23 with no problems correct?
BB6 Prelude TypeS Pistons
see andi was told that they have such little clearance that if there is any valve float it will bend the valves. but you dnt get valve float unless you have bigger cams?? so i don't kno if its risky or not..Originally posted by Dani Filth View Postsame bore size. frm compatible. should work. the only problem would be if they are taller than the h23 pistons due to the longer stroke.
You can have valve float with stock cams if you put the RPM's in around the red line on a set of 20 year old (lower spring rate) valve springs as well.
As for whether or not these will fit. The bore and material are no problem. H23?h22 are compatible that way. Now if you take into account that the H22 piston does have a 0.5mm higher compression height. They will give you approximately 13:1 compression in and give you 0.189" less piston to valve clearance in an H23 combustion chamber. also your piston will be 0.02" out of the hole. You could use a thicker head gasket to get back some of that clearance and drop the compression a bit though.Last edited by GhostAccord; 01-25-2011, 02:57 PM.
Ok soo do you think if i use a thicker head gasket i can pull this off. i have been doing a decent amount of research and your math is deffinately on point. its just i dnt wanna build this then mess it up and have too rip it apart again. this car is my daily right now.Originally posted by GhostAccord View PostYou can have valve float with stock cams if you put the RPM's in around the red line on a set of 20 year old (lower spring rate) valve springs as well.
Yes A thicker head gasket would work.
If you want to build it without messing it up you should clay the engine with the Type S pistons. You should also measure (cc) the pistons and combustion chambers to get your true static compression. That way you will know for sure. That way you can also calculate what head gasket and/or what octane gas you would need to run.
Look up PirateMcFred's build on HT. He did a very similar build that should cover all the bases you're wondering about.
http://www.honda-tech.com/showpost.p...54&postcount=6
