VSS question.
    VSS question.
    i have a 92 accord coupe with a f22a4 in it from a 91. My speedometer stopped working and threw a CEL, so i bought a new speed sensor, and replaced it this morning. Well, i took it down the road to make sure it was working and it did, but after about a mile, it stopped then threw the code again. Any ideas or suggestions?
    try cleaning the plug? (between the wiring harness and the speed sensor....)
    mine stopped working, the plug had come loose due to a broken tab on the wire.
    92ex CB7<-SOLD 93ex CB9shiftingshift73C10
      Make sure the connector didn't come back off.
      Be sure the VSS is secure.
      1997 Honda Accord EX-V6:
      Originally posted by James Matteu
      You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
        make sure you saved the package for the sensor. its entirely possible that the new one is faulty. i have seen people tear their cars apart looking for the solution to a problem because they refused to admit that the part they just replaced was no good. it happens.
        though the dirty connector or imperfect installation ideas above are more likely.
          thanks for the advice guys..checked all my connections, must be a bad sensor out of the box. will report back when i get a replacement thanks!
            i had the same problem, have you checked your ECU for codes?
            i cleaned mine and it fixed the problem
            Originally posted by scudweiser
            it will go vrooooooom bauggggghhhh mmmmmmaauuugggg. Still no mmmmmbAAAAAAAUUUHHHHHHH though.
            Do you have anything intelligent to offer, or are you just trying to whore up your post count?
