Door Latch for 90 coupe.
    After not being able to find the correct replacement for my CB7 with manual locks and auto-seatbelts a local JY gave me a door latch from a similar coup. The donor had normal seatbelts and the wiring plug coming off the latch has 4 wires, can I somehow rewire it (only using 3 wires) to work in my car?
    Or can I use a latch from a donor which has auto-seatbelts and elec locks, and just disreguard the elec lock wires and use my stock door linkage?
      Ok, I'm confused. You state that you have manual locks, but there are three wires coming from your latch? Are you talking about the actual latch that holds the door shut, or the inner door handle? A pic of the piece you're talking about would help.
        I think I know what you are talking about. Cars with auto seat belts have 2 door switches. One is in the latch mechanism itself and the other is in the door jamb. The switch in the latch controls the seat belts, so you will need the latch out of a car with auto seat belts. There is no way to rewire it.
        I think you should be able to use a power lock latch. Just take the little motor out and install it like the other.
            So the hunt is still on for a latch from a elec-seatbelt donor, if you have any leads let me know..
              Any 90-91 coupe latch at a junkyard should work.
