Would PWJDM PowerChambers fit?
    would any of the PWJDM line of PowerChamber's fit on an F22A1 CB7?
    i need an intake so i was wondering if these would work.
    if not..
    anyone know of any intakes that actually increase power?
    cause i'd rather not do the work for nothing..
    Originally posted by struckaccordCB7 View Post
    would any of the PWJDM line of PowerChamber's fit on a CB7?
    if not..
    Yes but you will have to get a smaller battery or located to the trunk.
    Few member got them for their CB..
    Just like any short ram intake... it does make power, you will have to tune it to get a real...realistic hp but normally a short ram put down about 2-5 hp no tuning.
    Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
      As far as I know you can use the H22 intake but like the guy above me said you'll have to move the battery.
        i'm alright with relocating the battery to the back, but i'm not entirely sure how to do it or what i would need to do the task..
          make the wires longer
          "My FOR SALE thread - Click here"
          MEMBERS RIDE
          99 SILVERADO
          WHEEL FLIP
            You'll need to run a power wire, at least 4 guage or bigger, from the trunk up to the engine bay to the same place that it goes to right now. You'll also need a battery box/proper ventilation for the battery if using the stock one. Batteries give off hydrogen gas so this needs to hae a way to be routed to the outside of the car. Ever hear of the hindenburg? This is hydrogen gone bad. Other than that you just need to ground it to a good spot in the trunk. It's pretty straight forward.
              There is a guy here in town with one in his 92-95 Civic I was going to buy, it fit quite nicely, considering it wasn't made for the cb chassis. I also have an h22, and deleted the map sensor box and relocated my battery.
                Originally posted by Brandoncb7 View Post
                I think that's the first time I've ever actually seen that video.
                MRT
                sneaky motherfucker
                  is that a video of the Hindenburg?
                  lol i can't see it since i'm at school..
                  and are there any DIY posts about the relocation of the battery?
                  i wanna get a good idea of what i should be doing before i actually do it..
                    Run a wire from the fuse box under the hood to the starter, run a wire from the starter to the trunk (or where ever you decide to mount the battery) then ground it. It's super simple. Just make sure when you run the wire thru the firewall you use a hole with a rubber grommet, or use one to keep the wire from being cut. Also, you'll want to have an inline fuse somewhere on the power wire, just to be safe, I did. And I wouldn't use any wire smaller than 4 gauge.
                      Yes my name is Dang, Don't use in vain
                      1992 Honda Accord EX (Coupe/Bordeaux/Auto)
                      1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
                      2008 Honda Accord EXL (Coupe/SanMarino/6spd)
                        ^^ Whos car is that??
                        Man Im really starting to want a white CB
                        Henry R
                        Koni/Neuspeed
                        1992 Accord LX R.I.P
                        1993 Accord EX OG since 'o3
                        Legend FSM
                          JDMHondaguy
                          Man I like that Stock CB in your sig! looks soooooo nice
                            Originally posted by vietkid_2006 View Post
                            The only problem I can see with this is having the battery where this one is is going to mess with weight distribution if that matters to you. Then again he's using an odyssey battery so it's relatively small. Just a thought.
                              very nice!
                              what model did you get?
                              i was gonna get the one for the civic hoping it would fit.
                              it looks similar to the shape i need. so..
                              i have a white cb as well
                              and they show the dirt alot, but damn they're pretty when you wash em=]
