Trying to Find a High Output Alternator
    I am trying to find a High Output alternator for my F22A1 just trying to save money dont want to keep replacing the OEM one two 10's and two 12's with a 2400 watts/rms amp will do that really looking for a 130-150amp alter. it would be grateful if someone could help me out??
    have you tried looking at ebay or summit? you are looking for a 170amp alternator, i don't see why you would have to keep replacing it, should be your battery taking all the punishment, also a cap should do you some justice if you cant flop over the $500 or so for the alt
    Originally posted by scudweiser
    it will go vrooooooom bauggggghhhh mmmmmmaauuugggg. Still no mmmmmbAAAAAAAUUUHHHHHHH though.
    Do you have anything intelligent to offer, or are you just trying to whore up your post count?
      Call a local automotic electrical shop, they can rebuild yours and build higher output into it. You will also probably end up with a nice 1 year warranty.
      Bought from Darkcloud
      http://wheelflip.com/r/DrAkE
        as for a cap there a wast of time and 170 is over kill and i did a lil looking online found one thats 130amp for $205 with shipping says its for a Prelude that has a F22A1 which i think will work its the same motor just wanted to make sure, and i know a 130amp will work bc i had everything in a 91 cavalier that i bought a 140amp HO alt for and everything went find and i would burnt the factory oem alt up and not the battery bc i have a yellow top and there beast lol
        http://www.maniacelectricmotors.com/hiou130ampal3.html
        this is the alt that im looking at
          http://www.f22parts.com/parts_page_Ignition.htm
          Definitely overkill but if its needed, then its needed
            when it comes to a different chassis you might have to get a relocation kit, i know ESP makes one for the F/H series, i didn't know there was a 130amp. as far as the yellow tops yea i know they beast it up lol, i had to get an Alt from an H22 for my F since it spins faster lol
              the 130amp will work without changing anything i looked up an alternator on autozone.com and they have the same part# for a 92 accord and a 92 prelude with the f22a1 so i should b ok, but thanks for the help if i have any problems when i get ready to put it in i'll be sure to hit ya'll up
