Car Won't Start AFTER STALLING
    Last time it was being driven, the clutch was released too early in first, causing the motor to lurch violently and stop. I checked the battery terminals, checked for vacuum leaks, nothing, but it still wouldn't crank. We tried push starting it, but it didn't want to start. I'm gonna get more into it later tonight when I get off, this is a repost because my old one got deleted (non descriptive title xP), but I wanted to see what you guys think.
    Thanks.
    Oh, the dash lights wouldn't work, headlights wouldn't work, it wouldn't crank/sputter/anything, BUT the brake lights did work.
    By not "cranking", do you mean the starter is not working?
      Have you checked the fuses? Your electrical problem makes it sound like fuses.
      MRT
      sneaky motherfucker
        I'm not sure if it's the starter, I wasn't having any problems with the car starting before. If it was the starter, I would still have power to the dash, no?
        And which fuses would those be? The ones in the upper left part of the engine bay? Or are there others?
          Check the 50 amp fusible link under the hood..... I think it's the red one.....
            There are others, and I would check them all.
            The others are located right next to your left foot while driving.
            MRT
            sneaky motherfucker
              Replaced all fuses. And nothing. Does anybody have a COMPLETE checklist of all components involved in ignition/interior lighting??
              So far I have:
              -Fuses
              -Starter
              -Alternator
              -Battery
              I know I might be vague with the first one, so ANY sort of details will be appreciated greatly!
                sounds like another bad main relay report . have you changed it ? try main relay search .
