Clutch Issue?
    Clutch Issue?
    In my 95 Accord wagon LX I had both the cluth salve and the clutch master cylinder replaced yesterday.
    Before doing so my clutch used to catch almost as you let off it not its real stiff and catches almost all the way at the top. I do not like this... Any ideas?
    Has the pedal height changed any at all? It may be out of adjustment on the end of the rod. If they used aftermarket parts, it may be something you're stuck with. There was a noticeable difference in stiffness between my OEM and the aftermarket master and slave. The OEM was much stiffer. It took me a few days to get used to the new ones. I still have the same response, it just takes less effort.
      Aftermarket parts were used. I dont mind the stiffness I just dont like that it engages at the top. Its not slipping as far as I can tell.
      I feel like i have no clutch...
        I know there's a way to adjust the pedal pressure some how. When I added my CM stage 2 clutch & lightened flywheel my clutch would also engage near the top. It takes a few days to get use to it, but if you don't like it I know there's a way to adjust it, I just don't know exactly how to do it. I have mine pretty much like stock now though which is nice
