I got in my car this morning and had no breaks. it just went straight to the floor. but If i turn the car off i have pressure in the pedal but if its on i have none. So i checked my break fluid and it was low so i topped it off. Only it didn't solve my problem. i looked around the M cylinder but saw no leakage but there's leakage under my car. Anybody know whats going on?
No Breaks? What happend?
Originally posted by WiggneedsJDM View Posti looked around the M cylinder but saw no leakage but there's leakage under my car.Your story isn't straight.Originally posted by WiggneedsJDM View PostOops my bad. Its late.
I checked the lines. no issues. Should i try to bleed? or just go for the cylinder and booster?MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Was it brake fluid?MRT
Clean your engine bay. It's much easier to find leaks that way.
Top off your brake fluid.
Have a friend sit in the drivers seat and stomp on the brake pedal.
Look for the leak.MRT
Thanks for the help guys. im looking into it. will a junkyard cylinder work or do i need a rebuilt one? Will i need to bleed the brakes when im done?
EDIT: also if im taking the M C out, how do i empty it?Last edited by WiggneedsJDM; 03-12-2011, 12:28 PM.
Junkyard cylinder is a gamble. Buy a rebuilt one or rebuild it yourself.Originally posted by WiggneedsJDM View PostThanks for the help guys. im looking into it. will a junkyard cylinder work or do i need a rebuilt one? Will i need to bleed the brakes when im done?
Yes, you need to bleed the brakes.
Get creative. I bought a siphon system from autozone for like $3. I've also heard of people using turkey basters. I wouldn't use it for food after that, though.MRT
just buy a remanufactured one. i paid like 30 bucks for mine from carquestOriginally posted by WiggneedsJDM View PostThanks for the help guys. im looking into it. will a junkyard cylinder work or do i need a rebuilt one? Will i need to bleed the brakes when im done?
