Removing A/C and P/S
    How do you remove the A/C and P/S system PROPERLY and keep the car working after? The belt that goes to the A/C compressor, what belt is that?
    Current:
    2007 Acura TL Type-S 6MT KBP
    Past:
    1992 Honda Accord EX-R Sedan - RIP
    1991 Honda Accord EX-R Wagon - RIP 10/14/2010
    Words change lives. You just got to choose the right ones.
    Instagram: @CB7Nub
    Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
    for the P/S just remove the belt, hoses, the ps fluid and the bracket and your good to go. you might regret it afterwards. for the AC i dont know since my cb is a dx model so never had it.
    AT WEST COAST MEET
    cb7rush: who has the tongs?
    JDMxDB8: i got a thong on...
    to get to see more of my cb click the link below.
    http://www.cb7tuner.com/vbb/showthread.php?t=130922
      It would be for not a daily so I wouldn't need the P/S. Plus it looks ugly IMO. A/C compressor has a belt and seems a bit more complex to me. Dunno though I'm pretty dumb about this type of stuff.
      Current:
      Past:
      Instagram: @CB7Nub
        If you're not sure about the P/S, just take the belt off. If you like it, start removing the system. If you don't, put the belt back on.
        A/C causes no loss of HP unless it's on.
        MRT
        sneaky motherfucker
          How much hp would you gain from removing PS? Or is it just something to clean up the engine bay?
            For the A/C, remove p/s pump, and alternator to have more access to the compressor.Then go ahead and remove as many a/c lines as possible, Unbolt the 4 or 3 nuts holdin the compressor in place and pull it out.(I believe you can remove the bracket as well). You can also remove the a/c fan (driver side) and condensor in front of the radiator (requires bumper removal).
            Swing by your auto parts store n purchase a DX accord- Non A/C alternator belt before you do any of this
              Completely guessing: 17-30.
              MRT
              sneaky motherfucker
                More like 1-3.
                OP, If you want to take the A/C out just get the belt for a DX without A/C.
                  a/cnd ps?
                  I would keep the a/c because it dose not use any power and its nice in the summer.with the power steering If you are set on getting rid of it you would have to change your steering rock to a manual one otherwise your car would be super hard to steer.
                  I would keep the power steering because it dose not use any power and make your car slower.your power steering pump pulley is not hard to turn at all there for its not going to slow you down. If you want to see just take the belt off and drive around.
                  Even if you took your power steering out and your whole A/C system all you gain is your car may way 15-20 pounds less and if you are trying to drop weight like that the gas in your gas tank is over 8 pounds a gal.
                  Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
                  93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
                    just remove everything completly and remove all belts, take the radiator out and remove your condensor. then you run one belt from the crank pulley to the alternator pulley. my car doesnt have a/c or p/s and its my daily. it only sucks when your at a dead stop tryin to turn, and i have an ex so the sunroof helps for the lack of a/c lol. doing this also leaves you with a fan that wont be used so im debating on using the ac fan as an extra cooling fan, but wiring it to a switch so i can control when it comes on, and just use it for when im racing, but thats just me
                    THUG LIFE!!!!!!
