how much for a head swap?
This topic is closed.
    i wanna throw on a h22 head on my f22 block wats the price and wats all the parts i need
    http://www.cb7tuner.com/vbb/showthread.php?t=177214
    research. start with search button at the top of the page. then move to google.
      Why in the world would you want a low-compression, low-redline mockery of an H22A that will likely blow up on you? Because you want VTEC, and think a headswap will be the cheapest and easiest way to do that? Think again my friend. If you don't know enough to do it without asking for someone to hold your hand, it's unlikely you'll have any luck building this worthless hybrid. The best way to do an h22 headswap is to use an h22 block as well. Makes it real easy
        heres what you need
        you will need to go on ebay and get a f22 head gasket set.(never use a falpro head gasket)You will also need to drill a oil passage hole in the block for oil to get to the h22 head.I dont know where but someone on here will.you will need to swap your water pump gear with a h22 one and get the h22 timing belt. people call a f22 block with an h22 head a "G22" look it up.If you think you will make the same hp as an h22 you WONT because the f22 has 8-1 compression and the h22 has 10-1 (I THINK)and a higher red line.I would put an h22 block in if you are going to do all of that wok.A "g22" will make about 170hp tuned.if you get the h22 bottom end to go with it wil will make 220hp tuned. you will still gain a few nice hp going with a "g22" tho. good luck!
        Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
        93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
          http://www.honda-tech.com/showthread....php?t=1046336
          here is a link for the "G22" .... its kinda old but hope it helps
            That's a good read.
            MRT
            sneaky motherfucker
              Please don't call it a G22.
              The G series exists, and this worthless hybrid is lacking a cylinder to be a G series.
                reply
                thanks for the help i guess imma just do the whole h22 swap
                  Smart man.
                  I'm going to lock this now, because we've said all that needs to be said about this... everything else has been said elsewhere.
