got a problem with a bit of grinding in 2nd, and in some cases 3rd, when the car is still kinda cold car shifts fine through the gears but when its all warmed up it grinds into 2nd, however it wont when i shift at a low rpm or double clutch... possibly be a bad sync or throw out bearing? or maybe something else? gladly accept any suggestions and/or advice
grindage with 5spd
A bad throwout bearing would have nothing to do with grinding gears. When that goes bad, you'll basically stall your car the minute you press the clutch pedal in.
The grinding is due to worn synchronizers. Change your fluid with Honda MTF or GM Synchromesh, and it may alleviate the problem for a bit. It won't fix physically worn parts, though.
92-01 prelude ... dont get the SH transmission unless you're willing to do the work.Originally posted by the 4eyed flaco View Postwhat specific year? any changes to wiring? will fit on a f22a4 block right?...
.. sorry i have a bad habit of asking a lot of questions
Most will required you to drill and tap three hole on the prelude transmission so you can mount the tranny in your Accord. All wirings should be the same if not just transfer your accord wires over.
