I've removed the disi cap and a couple other screws but I can't get past the disi rotor. Any special instructions on how to remove these pieces so I can get to my ICM? Thanks in advance!
How do I remove ICM?
If the rotor is from Honda, then there is a small Phillips head screw holding it in place. Remove that screw, and pull the rotor straight off. If it is an aftermarket rotor, it's just clipped on there, and can be removed by pulling on it. If it hasn't been removed in a while, it may be tough to get off. The ignitor (icm) is held in by two screws, with 3 wires on it (the wires will have a jelly-looking cover on the connections... just pull, those are attached to the wires and will come off with them.)
No problem.
If there's no screw on it, then it's probably a replacement part from an autoparts store. Nothing wrong with that... just no screw holding it in place, so it should pull off with some force. That OEM one with the screw is what you have to look out for... because you're never going to pull that sucker off without removing that screw first! I've seen people pull their hair out trying, not knowing it was there!
If your distributor still has the original OEM dust cover you will need to rotate the engine until the rotor is positioned so you can see the scew through the window cut in the dust cover.
Window opening circled in red, Yours may not be exactly like the one pictured. However if it has the black dust cover under the rotor it will have a small window where you can see the distributor shaft. This is where you need to rotate the engine so that you can see the Philips screw.Last edited by GhostAccord; 04-11-2011, 03:39 PM.
That was a hell of a day! I'm SO lucky my local Advance Auto is only a 5 minute drive away.
Turns out the disi was replaced with an OEM replacement after calling my dad to find out. Had I read GhostAccord's post before I attempted to pry it off, my rotor would still be in 1 piece
lmao
I ended up going back to the store about 4 times, haha. Gotta love spending an entire day off working on your CB.
Once I actually got to the ICM, I switched it out and applied that gellish stuff that comes packaged with the replacement. And I switched all four spark plugs for the hell of it (one at a time to avoid confusion with the wires). One was laden with oil so I may have a larger problem on my hands. Once I hooked everything back up to it's original fashion I hooked the battery back up and headed to the driver's seat.
The S.O.B. was dead
Took the battery back to AA; turns out it had 3 out of 12 volts; so to the slow charger it went. Today's project has been put on hold until I pick up the battery tomorrow.
What a day.
lol
