I was trying to use my cruise control and it doesnt work. I have no idea even were to start. Any help will be appreciated
Cruise control ?
Then something is wrong with the actuation. If the dash light is on then the system thinks CC is working.
Have you checked the vacuum?MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Most likely, it is a little puck that has broken and fallen out; where the clutch pedal meets the underside of the dash. With that puck missing the car thinks you have the clutch pushed in. If the puck is missing, you can put a bolt through the hole, and it makes a perma puck.
This happened to me, too.
Originally posted by LadyG View PostMost likely, it is a little puck that has broken and fallen out; where the clutch pedal meets the underside of the dash. With that puck missing the car thinks you have the clutch pushed in. If the puck is missing, you can put a bolt through the hole, and it makes a perma puck.
