This is my first post, so bare with me. so the other day, i helped my friend do an oil change and change the sparks on his 91 accord(i my self have a 92 by the way) and i was horrified at the condition it was in. so we did the oil change and it was horrible. only 2 and a half quarts came out AND when we put the new oil back in, it was brown when we rechecked it. we changed the spark plugs, and they literaly came out with pieces of rubber. we also changed two ripped little coolant hoses, and the pcv valve, and adjusted the iac valve(i think) cause it was surging up and down while idling. i told him we need to change:
1. air filer
2. fuel filter
3. distributor cap and rotor
4. spark plug cables
5. flush the radiator
6. replace tranny oil with dexron 4 syn
7. flush the motor
8. replace valve cover gasket(i think)
as far as the engine department goes, is there anything else you can suggest we do to this monstrosity?
1. air filer
2. fuel filter
7. flush the motor
