I'm having problem with squishy brakes. If I jump on them, they almost go all the way to the floor before they grab. If I pump them first, they grab sooner. I haven't seen any fluid leaking near the wheels, or by the master. Is the master just bad now? Don't wanna fix crap that ain't broke. Thanks guys.
Soggy brakes!
Master cylinder going bad would have pedal pressure but if you hold it steady it will go down. Do you still have brake fluid? I'd try to bleed the brakes first and since your car is up inspect the calipers and the rear wheel cylinders (if you have rear drums) for leakage.
As for fixing something that isn't broke bleeding your brakes regularly is good practiceWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by duffmanivxx View PostWe bled the brakes yesterday, no air in the lines. It's does lose pressure when I hold it down, so it sounds like the master. Thanks.
When I bled mine for the first time (ever), it killed the master cylinder.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Originally posted by duffmanivxx View Postnext week maybe...waitin on my check. Gonna lower my shit some more too!!MRT
Originally posted by GeoffMisiak View PostBrakes > Cheap suspension
