Possible roof rust?
    Possible roof rust?
    Are there called gutters?
    Anyway, I can't tell if this is peeling paint or rust. I may just sand it and paint it to be sure. Advice is appreciated.
    I can always go back and take stills if need be.
    MRT
    sneaky motherfucker
    It's hard to see but I think it's surface rust.
      i think also is a surface rust, i hard to say in the video but look really like this. with picture this can more easy to reconize.
        it's rust... take care before it got worst.
        Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
          I have a feeling it's leaking. How would I go about patching it? If it's small enough I'm going to try to weld a bead down the area. If it's too big for a bead, what should I do?
          MRT
          sneaky motherfucker
            The only trouble area on the passenger side. Right above the passenger.
            The rest are drivers side.
            I'm going to wire wheel the rust away. Still not sure what to do if it's through and bigger than a bead....
            MRT
            sneaky motherfucker
              Yep, water somehow got thru the sealant/paint.
              To fix it you will have to sand it down to shiney metal and seal the bare metal with epoxy primer and then rust proof it with some panel bonding to water proof it. Paint it to match and you're done.
                I vote rust! Good thing you caught it now.
