AC has some problem
    AC has some problem
    As i was driving the car, CHECK ENGINE LIGHT showed up and AC was already on,, some smell was coming out from the AC like something is burning , AC is blowing cold air,but some burning smell was in it,,,,? what could be the problem,,,after 5 minutes when the CEL showed,it went off,,any advice?
    is it the blower motor that would b burning inside? something is burning somewhere?
      comon guys,,give me a tip,,from where shud i start?
        First, I don't think your AC will throw a CEL.. Second, what did the burning smell like? Rubber? Wire insulation? Oil? Cat flesh? You really didn't offer much in the way of information in order to let us halp you.
        The first thing to do is go pop the hood and start looking for anything that looks burnt. Then start the engine and see if anything is smoking. Then see if you can pull any codes for the CEL.
        Unless your blower motor stopped blowing air at the same time, it was something else causing the smell. Since you had a CEL, it leads me to think that something under the hood (besides the AC) caused the problem and the intake for the HVAC system was pulling the smell in along with air.
