Fuel, but no spark. Help!
    So, my car started last night, but has been having problems lately. It would run for a while, get really hot, and turn off while I was driving; But would turn right back on! One time it tripped a CEL but I didn't know how to check it.
    I was doing some research and decided to change the Ignition Control Module, Cap, and Rotor. Hooked everything up. No spark what-so-ever. It just turns over. Any ideas? My next idea is the ignition coil. It's just weird because it started last night.
    *I also made sure the spark plug wires were correct on the distributor, and the connections that go to the ICM.
    Facebook.
    Xbox Live: Call Of Duty4: Unt0uchable15 --I'm a beast!
    Member Ride
    Sounds like you need to check out that overheating problem too, make sure your fuses are not blown. Is the distributor an internal coil or external? Under the passenger glove box there is a blue plug one of the wires are orange. http://www.cb7tuner.com/vbb/showthread.php?t=21259
      are you sure you got the wires correct on the ICM? http://alldatapro.com/alldata/PRO~V2...36288/41937481
      MRT: http://www.cb7tuner.com/vbb/showthread.php?t=183959
        Definitely check the ignition coil to see if its putting out current. I had the same problem a couple years ago and I just replaced the coil. It can also be the ignitor thats overheating. Make sure you have enough electrical grese on there and that the connections are tight. So it might be that.
          three things. what the guy above me says,
          and make sure the timing belt is intact, and also make sure that the dizzy rotor is spinning you could have seized the cam.
