car wont start
    ok so the main relay didnt help it still just crank and cranks. the fuel pump isnt kicking on or getting no spark and the cel still stays on solid with the key turned on and wont read no codes. u guy think is could be the timeing belt but would that cause the cel to on soild
      What did you do to the main relay? Saying you did it means nothing.
      You need to figure out if you're getting spark and fuel pressure
      Saying you don't have fuel pressure or spark means you have 2 different problems
      We aren't there to fix your car for you, we can only work with the information you give us and at this point you have not given enough to make any diagnosis.
        well i changed the dizzy, coil, ecu, and main relay and still nothing it just cranks with the check engin light staying on solid i kno its getting power to the dizzy and coil cause i tested it so i dont kno
          If you're not getting fuel or spark then it sounds like you have an ecu problem. Check the ECU fuse in the kick panel (inside the car) and the one in the main fuse box (under the hood, or wherever you relocated it to)
          1990 CB7 - Almost Done - Delta 272, SRI, 2.25 catback, Bisi intake manifold gasket, A6 intake double stacked, H22 plenum, AEM cam gear, F23a block, F22a head, Wiseco K20 pistons, DSM 450cc injectors
          2004 Z33 - Brembo BBK, Nismo spoiler, Nismo lip, Nismo shift knob, AEM CAI
            Are you just throwing parts at your car with out any thought?
            Figure out if its getting spark and fuel
            If its not getting one or the other THEN we can start a diagnosis but untill then we are shooting into an open field hoping to hit something
              its not getting fuel or spark i pulled the line off of the fuel rail and turned the key on and no fuel came threw and i pulled a spark plug and plugged it in the wire and cranked the car and it got no spark and i have checked both bothe fuses for the ecu and for the ignition
                someone help plz
                  Did you set the spark plug next to to the block or something metal?? And does your fuel pump work? Could be a bad fuel pump.
                  And you said you replaced the dizzy did you put it in right theres only one way it goes in.
                  Did you check all grounds?
                  Also you said you changed your ecu did you replace it with the same one that came with your car? Not just any ecu from another accord is gonna work unless is the same trim model, year, and tranny
                  1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
                  Originally posted by keepinitclean
                  I give it 2 weeks before you sell it.
                    yes i did ground the plugs out on the a bolt on the block and yes i put the dizzy in right and the ecu was from another 92 lx just like mine
                      check the ecu ground by the thermostat housing.
                        ok cool anything else that u guys may kno about? do u think it would be the wiring harness
                          Could be. But im sure its something simple. Like he said check that ground or actually take out the bolt and sand/clean the connections for a fresh ground.
                            cam sense maybe bad wont get fuel or fire
                              My ground to the thermostat housing broke and caused this exact problem. Check your grounds.
                                but would the cam sencor make the check engien light stay on tho cause it wont read no codes and i have check the grounds and i cant find nothing bad
