A little help with this noise!!
    Well this noise just started today and not sure if it's coming from the belt or a bearing. Oh and it gets louder as you rev it up.
    http://www.youtube.com/watch?v=rMVnO...e_gdata_player
    Take a look at my MRT!! Thanks
    http://www.cb7tuner.com/vbb/showthread.php?t=186609
    damn. my cb just stated doing the same thing! thanks for making a vid.
    it sounds rhythmic. and from the close up shot of your timing belt (i think thats what it was) it looked to be moving side to side with the rhythm.
    "My FOR SALE thread - Click here"
    MEMBERS RIDE
    99 SILVERADO
    WHEEL FLIP
      Yea it does look to be in sink with side to side but it's hard to tell were exactly the sound is coming from.
        usually when im in situation like these were i have a noise. i just take it to a shop and have a pro hear it. if he knows his shit he would be able to tell where its coming from and maybe even why with no charge. if somehow you fall into their traps and end up paying some cash its your fault.
          Hahahaha. That's some great advice..
            Lol yea that is some grate advise. But was hoping for some one here to know there shit.
              Having someone look at it in person is going to be a lot more helpful than having someone watch a video and try to diagnose the sound that way. Taking it to a pro is honestly one of the best pieces of advice you're going to get... unless you want to start randomly replacing parts until the noise goes away.
                Turn your wheels back and forth and see if it changes the sound. It may be the P/S Pump. Seemed to me like the sound was more audible there. If not take off your drive belts one at a time and see if the noise remains. You should have the answer after that.
                  Ok thanks guys, I will start with the belts then to a shops if that was not it.
                    im know expert but its coming from the timing belt. you can clearly see it moving side to side and making that noise. have your mechanic check the tensioner and the belt itself...good luck man, i think honda advises changing timing belt at 90k miles on most cb7's? so if its never been done that might be it
                      Probably the timing belt rubbing against the inside of the lower cover. If you are going to do the work yourself you are going to ahve to remove the crank pulley and the bottom cover to do a more thorough inspection. Probably a good time for T belt & B belt change.
                      MR Thread
                      GhostAccord 2.4L Blog
                      by Chappy, on Flickr
                        Yes i will be doing the timming belt and delete b/b. And just for good measer the timing belt tensioner too. Thanks for the help guys.
                          does the noise change when you turn the wheel side to side?
                          i wnt through a few steps today. and found out the harmonic balencer was coming apart and rubbing on one of the belts.
                          MEMBERS RIDE
                          99 SILVERADO
                          WHEEL FLIP
                            it sounds like your water pump bearings are shot causing the shaft to wiggle. that may be why your timing belt is moving with the noise
                              No it doesn't , I took off the two belt to try to find the noise but did not, it is still doing the noise but not insync with the belt anymore. It is time to change the belt so I'm going to do this and the water pump too. I will not have the b/s belt anymore so one less thing to worry about.
