Just bought a 91 EX coupe and the gas and temp gauge didnt work. I fixed the temp gauge(wire was loose) but when i called the parts shop for the fuel gauge sensor they said they dont carry it. Im wondering what the sensor is called??? Sounds like a noob question i know but ive been working on cars since i was 13 and now im 19 and i know alot about cars and always called it the gas gauge sensor. So what is it called? and can i only get it from Honda?
Fuel gauge sensor question
Bought from:AbsurdNY,92smokeaccord,cb7inct,nevi325,xkjnboix,cb 7resurrector,JoshM
MRT: http://www.cb7tuner.com/vbb/showthread.php?t=203451Tags: None
Originally posted by '93CB7Ex View Postshould be the sending unit in the tank.
if you go in the back right corner of the trunk there is a panel held down by 3 screws. Open it and thats where the gas gage float is,Take it out and clean it. That could fix it if not I would get a junk yard one. Honda should know what it is.
Im bumping up the thread because i just started working for Advance Auto Parts today and get 20% off
And my gas gauge is still broken and i just threw 5 bucks a day in the tank so theres gas to get to work and back and i asked afew people today at work and they said its yhe fuel lever sender but im still not sure if its that. The link below is of the part...Let me know if this is the right part or not. Thanks
http://shop.advanceautoparts.com/web...7CGRP2032_____
Thats it. To take it out you just open a panel in the back of the trunk. Its kinds trickey to get out of the tank. there is thin ring thing you have to hammer with a screw driver to get it to come out.
This is it
Uploaded with ImageShack.us
Originally posted by thepowderblue View PostThats it. To take it out you just open a panel in the back of the trunk. Its kinds trickey to get out of the tank. there is thin ring thing you have to hammer with a screw driver to get it to come out.
This is it
Looks pretty simple. Just take off the cap and go from there. Now if i take out the old one is there a way i can save it instead of replacing it? Or should i just buy a new one?
Originally posted by thepowderblue View PostYou might be able to clean it up and it will work. Its easy enough to get to you might want to save some money and go to a junk yard.
Originally posted by thepowderblue View PostThey should all be the same... I would take yours out and put it back in before you go so you know how to do it. Its kinda trickey to get it out as far as unmounted.
I am in arizona and I cant be in the junkyard for more then an hour before I get dizzy and dehydrated so I like to know what I am doing before I get there and have all of the tools I will need.
Its just weird getting it out. There are some tabs you have to bend and you have to hammer this ring around to get it to come out.Last edited by thepowderblue; 06-28-2011, 07:36 AM.
Alright thanks
I plan on going to the junkyard as soon as i get my 1st paycheck and do i have to replace the ring? I see that my job got them
