Leaking tranny fluid
    So my car has never leaked and today I was getting on the freeway and I punched it to pass a truck and then my car starts making a weird noise almost like my tires where rubbing. It didnt last long. I Pulled over and sat on the side of the freeway and everything seemed fine.. I looked at everything and it looked to be good. then I took off and it started smoking and I was like wtf! So I guess tranny fluid on the downpipe.
    There back is fluid on the back of the tranny. After I drive it now it drips alot.
    I was wondering if that sounds like a axle seal or a split case?
    I have not bottomed out in a long time.
    What could cause this?
    Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
    93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
    check your fluids
    if it was on the downpipes. get underneath you car an look around...
    "My FOR SALE thread - Click here"
    MEMBERS RIDE
    99 SILVERADO
    WHEEL FLIP
      I did and they are good but its leaking tranny fluid from the back of the tranny and I cant tell where it is coming from.
        Have a look and find out where it's coming from.
        It's not like people can have a look for you through the internet.
        Clean the area off, and go for a short rive, then have a look for fresh fluid leaking - Follow the fluid to the leak.
        My 5.7 LS1 Holden Ute
          if this is an auto trans. i think theres a "overflow tube" in the back. if the atf starts to foam, it will drain out.
          but you really should find this leak. you dont want to be driving, and run out of fluid.
          MEMBERS RIDE
          99 SILVERADO
          WHEEL FLIP
            Its a auto.
            I was out partying last night lol.
