so my accord shakes when it idles but once i give it some gas it stops shaking, these are my engine mounts right?
my car shakes when it idles
Originally posted by billybmxer13 View Postroughly around 750 now, my buddy raised it to about 1500 to get it to stop shaking but i lowered it becasue 1500 is too high, this guy told me that its the mounts and i should get my idle raised by using a computer
YES go check the mounts!
The shaking is only at idle, correct? At any power band while moving, it's not doing anything that's strange?
Originally posted by thepowderblue View PostOmg, go and look at them if you think they are bad!Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by thepowderblue View Postbalance shaft belt may have broke.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
I am normally really nice but how stupid are you? Look at them. If they are broken then they are bad, If you cant even tell if you have a bad mount you should not be working on your car.
If your car is a A/T then set the parking brake and put your car in gear and see if your motor moves alot and if it shakes... That normally means you have bad mounts.
Originally posted by dj_ender View PostYeah thought that too, but its pretty common for us on here to have that mod, s.
Uploaded with ImageShack.usLast edited by thepowderblue; 06-25-2011, 11:54 PM.
Removing the balance shaft belt does not make your engine shake at idle. They are used to counter higher rpm vibrations not actual engine shakes. It was put in so that the old farts wouldn't be able to feel the slight vibration at certain RPMs.
OP,
Do not adjust your RPM's for broken mounts. Replace them!
Originally posted by thepowderblue View PostI am normally really nice but how stupid are you? Look at them. If they are broken then they are bad, If you cant even tell if you have a bad mount you should not be working on your car.
Its not a mod. Its stupid people making there engines run ruff. They think its less mass for the engine to turn so they will get more power if they cut the belt. I only vote delete them if you are doing a build.
And I for one HAVE done the MOD, Yes it's a mod. And my car shakes a tad at lower rpms, but the throttle response is better and it helps on the top end. I don't know where your getting your info from, but I disagree with it.
And maybe he doesn't know enough about cars or as you stated too lazy. So what, give him a couple of ideas and if he won't listen or accept the help, stop posting on his thread, pretty simple. He came here to ask a question and got shit on by the usually nice guy.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
