I know I know. There have been a million threads like this. But I could not find a solution. My car starts and idles up nicely drops to around 500rpm then sputters out and dies.
I have checked all vacuum hoses. Check
I have cleaned IACV and FITV. Check
New Coolant hoses on half the car. What I could afford atm.
Tightened throttle cable. Raises my initial idle but still idles down and dies.
You are the CB7 geniuses. Collectively, we can solve this......
HELP!
HELP!
Then re-read the posts and went and did it again. CCW this time. Also, I bled the coolant system good. The engine was still warm and sprayed me. Bleh. I let it spray out though and then filled from the cap until it was pouring out the bleeder. So I am pretty sure it got bled good. I am holding a steady idle of about 500 rpm in reverse or drive. still pretty bouncy and weak.
