Any luck? If the idle is surging and bouncing around I would try looking for a vacuum leak or an intake manifold gasket leak. It is possible the IACV is going bad, but from what I've read on here that normally doesn't happen. You can test the IACV using a DVOM, but I'm not sure of the values you are looking for, so you might check with a service manual on that.
Idle down to Engine death
Originally posted by s2cmpugh View PostAny luck? If the idle is surging and bouncing around I would try looking for a vacuum leak or an intake manifold gasket leak. It is possible the IACV is going bad, but from what I've read on here that normally doesn't happen. You can test the IACV using a DVOM, but I'm not sure of the values you are looking for, so you might check with a service manual on that.
93 LX - Needs work
The extreme vibrations at idle could be worn mounts, especially since yours is an auto and uses a fluid filled rear engine mount that does run on vacuum. If that rear fluid filled mount wears out, it will cause the engine to vibrate more at idle. It's not tooo hard to replace, just need to remove the intake manifold (use a new gasket), support the engine from underneath, then replace the mount.
It is normal for an auto to drop in rpm's a little when putting it in drive or reverse, but 1000rpm hot idle is too high. I'm a little stumped too, but start with the simple things and then we'll work to the more complicated ones. Is it possible to swap your IACV with a known working one?
Originally posted by s2cmpugh View PostThe extreme vibrations at idle could be worn mounts, especially since yours is an auto and uses a fluid filled rear engine mount that does run on vacuum. If that rear fluid filled mount wears out, it will cause the engine to vibrate more at idle. It's not tooo hard to replace, just need to remove the intake manifold (use a new gasket), support the engine from underneath, then replace the mount.
93 LX - Needs work
Well when you adjusted the base idle with the IACV disconnected it should only be around 600, then plugged back in it should go back up to around 800 or so. Try checking for vacuum leaks around the intake manifold and see if anything happens to the idle. It seems odd that the idle ONLY messes up when you put it in drive, but when you load up the electrical system it still idles normally. That makes me think the IACV is still working OK....reset base idle perfectly, check for vacuum leaks, then we'll go from there.
Originally posted by s2cmpugh View PostWell when you adjusted the base idle with the IACV disconnected it should only be around 600, then plugged back in it should go back up to around 800 or so. Try checking for vacuum leaks around the intake manifold and see if anything happens to the idle. It seems odd that the idle ONLY messes up when you put it in drive, but when you load up the electrical system it still idles normally. That makes me think the IACV is still working OK....reset base idle perfectly, check for vacuum leaks, then we'll go from there.
93 LX - Needs work
Alright. Update. Adjusted idle after bleeding coolant system and cleaning IACV and FITV. Park/neutral idle are perfect. Reverse/drive idle bad low. like 200-400 if it even stays running. Now I am throwing a CEL. Fml. I remember how to check these codes but gotta start on dinner. I will try to find out the code tonight. Ugh.
93 LX - Needs work
Originally posted by drewams View PostWill do. You are a life saver for helping out. Can't explain how much it has been stressing me out. Looks like it may have to wait until tomorrow though. Storming a little here. Hopefully it will clear up. The idle is a little higher because I adjusted it there. The shaking at idle is super annoying and kind of embarassing lol. I will tune it and see about doing the motor mounts as soon as I can afford it. They are somewhat expensive from what I have found.
Originally posted by drewams View PostAlright. Update. Adjusted idle after bleeding coolant system and cleaning IACV and FITV. Park/neutral idle are perfect. Reverse/drive idle bad low. like 200-400 if it even stays running. Now I am throwing a CEL. Fml. I remember how to check these codes but gotta start on dinner. I will try to find out the code tonight. Ugh.
Begin with the EGR since that is the simplest. Check all vacuum lines running to the EGR valve to make sure they are connected and the line itself is not cracked. Then check to make sure the electrical connector is firmly in place. If all those check out OK, then remove the EGR valve, clean it using carb cleaner and check to make sure the little rubber thing underneath isn't cracked or broken and moves OK. Reinstall using a new gasket, then hook everything back up. Here is a picture of a dirty and clean EGR valve http://www.cb7tuner.com/vbb/showthre...&highlight=egr Still consider cleaning out the EGR ports as well, especially if it's never been done. EGR valves do sometimes fail on these cars.
TPS: This one is a bit odd as a TPS rarely fails on a Honda. Make sure your throttle cable isn't too tight and still has some slack in it at hot idle. Have you changed or messed with the TPS in anyway? If so, here is a link showing how to properly reset the TPS http://www.cb7tuner.com/vbb/showthre...&highlight=tps TPS failing is extremely odd and rare, but if the throttle cable is too tight I guess it could throw it off.
For IACV...I can't find any proper tests on this one. Perform the other above cleanings/tests first and see what happens. I honestly doubt all three are bad at the same time, but it is possible....well anything is possible I guess.
Keep me posted and chin up!
Cris
Originally posted by s2cmpugh View PostBegin with the EGR since that is the simplest. Check all vacuum lines running to the EGR valve to make sure they are connected and the line itself is not cracked. Then check to make sure the electrical connector is firmly in place. If all those check out OK, then remove the EGR valve, clean it using carb cleaner and check to make sure the little rubber thing underneath isn't cracked or broken and moves OK. Reinstall using a new gasket, then hook everything back up. Here is a picture of a dirty and clean EGR valve http://www.cb7tuner.com/vbb/showthre...&highlight=egr Still consider cleaning out the EGR ports as well, especially if it's never been done. EGR valves do sometimes fail on these cars.
Cris
Ok. I am retarded. I was messing with the TPS and EGR valve and they weren't plugged back in correctly. New IACV and FITV ordered. Found them relatively inexpensive. We shall see how that helps. I reset the ECU. No CEL for now. Still idles a little low in Reverse/Drive but doesn't die. It may just seem low to me because of the shaking I mentioned. Engine mounts more than likely. After recleaning the IACV - thats why I chose to replace it.
93 LX - Needs work
Originally posted by s2cmpugh View PostLOL, well those things unplugged would cause a CEL. Hopefully a new IACV will fix everything. If it still vibrates roughly at idle, then I'd look into the condition of the mounts.
Cris
93 LX - Needs work
