I'm replacing the passenger side upper control arm with a Dorman model. My car is completely stock.
The UCA came with the pivot bolts quite loose and I know it should be torqued to 22 ft/lbs. Should the bolt be torqued after installing the arm.....or can I do it prior?
Also, my Haynes manual states to align the upper arm anchor bolt with the mark on the upper arm. I cant find any mark on the arm.......
Thanks very much.
Thanks very much.
as for the anchor marks i have never seen them on my new control arms. i just aligned it with my old one. your control arms will always move up and down on the pivot bolts.
RIP 4/23/12
...lets not forget, the 88" Z31 turbo, are my dailys
