Engine: f22a4, 5spd mt
Custom green painted valve cover
AEM CAI
BB4 AEM 3" CAI Custom Green Powder Coating
Skunk II 68mm throttle body
H22ax throttle body(not installed)
H22ax plenum
F22a6 spacer/butterflies(not installed)
F22a6 runners
AEM red anodized fuel rail(not installed)
AEM red anodized fuel pressure regulator(not installed)
BlackTraxx IAB spacer
Bisimoto thermal intake manifold to head gasket
Ported and polished head
ARP H23 head stud set
Bisimoto pro springs
Bisimoto level 2 cam
AEM adjustable timing gear
AEM power pulleys
Bisimoto V2 ceramic coated header
KTeller 2 1/2" stainless steel mandrel bent plumbing
Apexi WSII 70mm oval muffler
Magnaflow catalytic converter
Vibrant Racing 2 1/2" in/out 4" of 18" bottle style resonator
CX racing V-Band flanges
vibrant performance header flange
DC Sports EX header(not installed)
DC Sports cat back exhaust(not installed)
DC Sports battery hold down
DC Sports oil cap
Optima Battery
FFC Fender washer and screw kit
FFC radiator hold down brackets
Fidanza light weight aluminum flywheel
Future Engine:
HASport rear engine mount
HASport transmission mount
fuel injectors
AEM ECU
Suspension
Tokiko illuminas
Ground Control Coil over sleeves with Eibach springs (CD spec.)
Eibach sportline springs (not installed)
GSR front adjustable camber kit
Explicit Speed Performance Traction Bar System
FFC billet aluminum extended top hats w/ arp 12pt hardware
FFC CD rear LCA
FFC CD rear toe arms
DIY rear upper control arm washer trick
Suspension Techniques front & rear sway bar set
DC Sports front strut tower brace
DC Sports rear strut tower brace
DC Sports rear lower tie bar
Energy Suspension master urethane set
Future Suspension:
Adjustable shock absorbers TBD
Brakes
Front:
Centric drilled and slotted rotors
Porterfield RS4 pads
Duplicolor red caliper paint kit
Rear:
Disc brake conversion
Powerslot rotors
Rollers
•16x7,4x114.3,+40 Sprint Hart CP-R, wrapped in 215/45r16 Falken Azenis 615k
•16x8, 4x114.3, +32 (front), 16x7, 4x114.3, +32 (rear) ENKEI/BBR Comp 6 2 piece. wrapped in 255/50R16 (f), 205/55R16 (r) Yokohama ADVAN Neova
•18x8,4x114.3&5x114.3,+42 Racing Hart EVO C4, wrapped in 215/40r18 Yokohama Prada Spec2 SOLD : (
•stock 195/60r15 wrapped in Yokohama (not installed)
Exterior
91 Honda Accord EX coupe, Frost White
JDM power folding mirrors (not installed)
Custom DIY USDM 90/91 factory fog lights black housed and yellow capped bulbs (not installed)
Custom JDM black accented fog light lenses installed on black housed fogs with yellow caps
DIY USDM front grill blacked out (not installed)
JDM 90/91 grill
Red eBay front Honda Badge (not installed)
PIAA Xtream 9006 bulbs
eBay clear / DIY custom black housed turn signals with amber bulbs
APC clear turn signals with amber bulbs (not installed)
DIY eBay euro clear corner lenses, custom black housings, with added and modified light diffuser (not installed)
APC euro clear corner lenses with PIAA yellow bulbs and super white bulbs (not installed)
OEM 92/93 hood bra (not installed)
VIS carbon fiber hood
Rear eBay clear/red tail lamps (not installed)
JDM 90/91 tail lamps
OEM flushmount rear lip
OEM DIY modified front mudflaps (not installed)
OEM rear mudflaps (not installed)
OEM EX-R DIY modified rear mudflaps (not installed)
JDM 90/91 Front bumper
GReddy GRacer front lip
Checkered Sports angled license plate bracket
JDM 90/91 Side Moldings DIY custom coupe version with chrome strip
Xenon Mild side skirts
Xenon Mild rear lip
OEM Sunroof Visor
Silblade silicone white on white wiper blades
JDM 1 piece headlamps 90/91
JDM 1 piece headlamps 92/93S SOLD : (
JDM OEM sidemarker
92/93 grill SOLD : (
Interior: stock Honda Blue
Tuning Shop aluminum dial rings
LED back lit instrument cluster
Wagon cluster circuit board and Speedo gauge
Apexi SAFC II (not installed)
Personal Neo Grinta Steering wheel, white with black spokes (Previously owned by Ronaly Type-R)
Momo steeing wheel adaptor
Works Bell Rapfix II Quick Release - Yoshioka Special Edition
Works Bell Quick Release Lock
Personal shift knob - Custom pearl white powder coat (originally polished fininsh)
Prelude shifter
FFC Solid shift cable bushing
DC Sports BB4 short shift adaptor
Varad lighting led's (aqua)
Trunk: bare
Varad lighting led's (blue)
Dynomat
Audio
Clarion HU VRX765VD
Boston Acoustics Pro 6.5.2 components (not installed)
JL audio 6x9
Phoenix Gold XS4300 (not installed)
Phoenix Gold XS2500 (x2) (not installed)
Phoenix Gold XS fuse block (not installed)
Monster Cable
[/url]
and you're close to the valley!
helllooooo there
