ok so i have been hering weird sounds when i hit bumps, took my passenger side wheels off and am checking brakes out and everything. well i get to lookin at the rear passenger side and the disc is able to move a little. also i notice that the hub bearing is loose(the part where lug nuts go). now i havent noticed the retaining screw in as there does not seem to be a hole for it. i wanna know if this is common for it to be loose like this. it is not up to my standards and worries me a bit. i will be doing the legend caliper and disk swap soon but i dont have the money right now, gotta wait till next check.
brakes
brakes
Accord SE
93se
Members Ride
Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
Sold to: sulimed, BurtonRiderT6, tishockTags: None
Sounds like your wheel bearing is shot.
We have captive rotors, so there are no retaining screws on them as with rotor-over-hub types. The rotor is REALLY on there, and it's pretty much impossible for the rotor itself to come loose. In fact, it's quite difficult to remove it when you want it to come off!
oh. ya i mean it is all deff loose. im actually taking it apart right now. it seems like almost the only thing holding it on was the caliper.Originally posted by deevergote View PostSounds like your wheel bearing is shot.
thanks for the fast response too man!Accord SE
93se
Members Ride
What do these wierd sounds sound like? Grinding, clucking, knocking? Does it only make them when you go over bumps?
The discs usually have a counter sunk philips screw that secures them to the hub. The factory installs them to hold the rotor in place during manufacturing. They are usually not really necessary since the wheel clamps everything together when you mount the wheel. You can get more and install them if your worried. Motormite makes factory replacements. usually in the help section at any autoparts store.
Purchased From: busak87, GunRunner, Bruce Banner, Itstatcb7kid707, tJoods, DannyD
The Caravan 2015
MRT:http://www.cb7tuner.com/vbb/showthread.php?t=180919
more like a clanking, not as deep as a clunk, and ya that counter sunk screw is not there. sry im not too good with the terms, and so far ive only here it hitting a bump. i am loweredon fnf ones and everything attached to them seem tight. but like i said where the lug nuts go on the bearing/hub? its loose and the entire disc is loose. the only thing holding it on is the caliper. i know cause i just took that off and am waiting on my friend with a 14 mm socket so i can take the bracket off to take the caliper off to check the bearing. sry if im using run on sentences.Originally posted by SanJoCaF22DrAcc View PostWhat do these wierd sounds sound like? Grinding, clucking, knocking? Does it only make them when you go over bumps?
The discs usually have a counter sunk philips screw that secures them to the hub. The factory installs them to hold the rotor in place during manufacturing. They are usually not really necessary since the wheel clamps everything together when you mount the wheel. You can get more and install them if your worried. Motormite makes factory replacements. usually in the help section at any autoparts store.Accord SE
93se
Members Ride
How hard are you finding it to change the bearings I have to do the same to my two front hubs and I've never done it before wish there was someone to show how to do them lolOriginally posted by esskater892 View Postmore like a clanking, not as deep as a clunk, and ya that counter sunk screw is not there. sry im not too good with the terms, and so far ive only here it hitting a bump. i am loweredon fnf ones and everything attached to them seem tight. but like i said where the lug nuts go on the bearing/hub? its loose and the entire disc is loose. the only thing holding it on is the caliper. i know cause i just took that off and am waiting on my friend with a 14 mm socket so i can take the bracket off to take the caliper off to check the bearing. sry if im using run on sentences.
Usually when a bearing goes out you get a grinding noise. I suspect a ball joint or upper shock mount, possibly even a shock.
The Caravan 2015
The brake design you described is a rotor over hub design. That is not what these cars have, unless they have been converted. Have you ever even worked on the brakes of a CB Accord? You are giving misleading advice.Originally posted by SanJoCaF22DrAcc View PostWhat do these wierd sounds sound like? Grinding, clucking, knocking? Does it only make them when you go over bumps?
The issue he is describing is very unlikely to be a shock mount or shock. The ball joint is possible, but the movement would be much more evident as the whole knuckle (and if the caliper was the only thing holding the rotor in place, then that means the caliper was stable... meaning it is NOT a ball joint.)Originally posted by SanJoCaF22DrAcc View PostUsually when a bearing goes out you get a grinding noise. I suspect a ball joint or upper shock mount, possibly even a shock.
Everything points to a completely failed and separating wheel bearing.
This video deals with the same type of rotors (it's on a 97, but the brakes are nearly identical for what we're discussing here.) Look closely at how things are put together as Eric takes it all apart. That's what you're dealing with. That video (and the one on replacing a wheel bearing) is pretty much all you need to fix this problem.
