ram air question
ive run a bumper scoop to my SRI for years. as far as performance gains not really different than anyother SRI. as far as highway driving or driving above 40mph i gain all of the benefits of a CAI. my direct air intake on the highway keeps my temp needle slightly above the cold mark and usually highest it goes is 1/4 when its normally at 1/2. i love it and so does my engine and gas mileage. i made a road trip to pick up my c/f hood to florida a few years back and got 450-500miles every tank of gas with this baby no exaggeration.
Originally posted by xkjnboix View Postive run a bumper scoop to my SRI for years. as far as performance gains not really different than anyother SRI. as far as highway driving or driving above 40mph i gain all of the benefits of a CAI. my direct air intake on the highway keeps my temp needle slightly above the cold mark and usually highest it goes is 1/4 when its normally at 1/2. i love it and so does my engine and gas mileage. i made a road trip to pick up my c/f hood to florida a few years back and got 450-500miles every tank of gas with this baby no exaggeration.
93 cb7 ex coupe
Granada Black Metallic
Originally posted by xkjnboix View Postive run a bumper scoop to my SRI for years...
Originally posted by xkjnboix View Post...450-500miles every tank of gas with this baby no exaggeration.
I see your sig, but your tire diameter is not visible..Last edited by islandhopper; 07-14-2011, 03:38 AM.
Originally posted by Turbocutlass View Post...because the higher in rpms the more the motor has to labor to pull the air from down there, where with this set up it doesn't have to pull it, its being forced in thus making the motor work ALOT less for more air...
Even if the velocity of the air is higher when entering the intake, there will be less of it actually moving through the pipe compared with a standard setup.
Air will choose the path of least resistance when faced with the blockade that is a car. Instead of entering the small turn-signal opening, air will find it easier to travel up and around the car. Thus, only with a large, aerodynamically-designed intake opening will you see a true ram-air effect. And even this - only at high speeds.
I really don't want to present a lesson in fluid dynamics on this topic again, so please: do the stick-your-head-out-the-window experiment that Deevergote mentioned and see for yourself.Original-Owner 1991 Honda Accord
2005 Acura TSX 6MT
2010 Mazda Miata Grand Touring
The butt-dyno isn't always efficient. Usually it's all in your head for little things like SRI's, and CAI's. Routing more ait to it won't do anything because it will only take what it needs. Unless the incoming air is positive, such as in a turbo/supercharger application.'93 LX Wagon (On the back burner)
'92 EX Wagon (Traded)
'93 EX Wagon (Current DD)
And to just add a tiny bit more....in the coldest of winter, it hits and maintains that same mark or VERY close to it.
Originally posted by deevergote View PostStick your head out the window like I said in my first reply... that will give you a much more accurate idea of how this will work.1993 Accord LX Coupe 5spd
Originally posted by ssondubs View PostMy head is round so air would have to go around it but an air scoop would be more like a funnel so air is forced to go through it would it not?
A properly designed scoop that really does manage to collect rushing air can be useful. However, most scoops are used for cooling, such as brake ducts, or the scoop on a WRX/STi, which is driving air through the top-mount intercooler.
An intake with a functional scoop would only be working at optimal efficiency at a very narrow point as well. When there isn't enough air flowing in, it won't be any different than a regular ambient-air intake. When there's just enough air flowing in, it will work best... but that will pretty much only be at a specific speed, paired with a wide open throttle. When there is too much air flowing in, the intake charge will be very turbulent. Turbulent airflow is one of the largest restrictions in an intake/exhaust design.
The engine is cooled by the water/coolant flowing through the water passages in the engine, and through the radiator.
Of course, an engine has an optimal operating temperature... cooler isn't always better.
