whats front upper arm fits right for our cb's? im searching for a alternative way..post your knowledge guys..
upper arm
I am assuming you mean a front upper arm on a lowered CB, and also that you are trying to correct your camber...
I got a set of these a couple of years back to address the same issue, and have had ZERO issues with them.
http://www.tasauto.com/Product/Detai...805&d=1546&p=1
Well you're in luck. The upper ball joint is built into the upper control arm. You're not supposed to separate them.Originally posted by cb3 vtec View Postmy car is not lowered bro,just searching for a normal upper arm,the mechanic said my upper arm is damage or the balljoint is worn out..so i need to change it a.s.a.p
Go to your local napa or autozone. They'll run you upwards of $50 each. If you get close to $100 go to the dealership.Deev and I are buds
i my self have ef upper control arms they fit perfect but u only get like 2 degree's of correction ...............im thinkin of getting some anchor bolts also so that way i have double the adjustment
ef,or crx upper control arm wit the adjustable ball joint will work there all the same i also found out today to that there rear lower arms fits our car also an thats my next upgrade will post sum pics when i get them on............................
