propane in your ac system
    So I met this guy today and he knew alot about hondas.He was telling me that you can evac your car ac system and add pag oil and you can charge it with propane. He was saying its easier on your compressor and it gets colder.
    I know fridges in rv and stuff run on propane. what Is known about this?
    Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
    93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
    I've never heard of that. Propane is so combustible that I'd be nervous to put that in my AC system, even if it does work.
      Well like I said I have seen rv's that use propane to run there fridges.
      So the pressure from the bottle must push it threw a condenser and it must cool so I dont see why it wont work in a car.
        It works, and people do it. In fact, some official refrigerants are hydrocarbon based. Yes, they are flammable. Yes, they can explode. No, it's not likely. No, I don't recommend it.
          it does work, actually it works very very good
          but is not colder, your a/c system has a thermo switch and its set a 50degs, anything less than that, the system will turn off the compressor so it aint colder
          the pressures are different, so who knows whats the right pressure on low/high side
          come on man its, propane...... my wife is mainly the passenger on my car, being that the evap unit is on the passenger side, you do the math
          i aint going to say i will never rear-end someone but.....shit happens
          Just do what PR CB7 said.
            I'm a universally certified HVAC tech, and I've never heard of it. I wouldn't even try it.
              I wanna try it...I herd its easer on the compressor.
              Do you know if I will have to change the dryer and Do I need to give it a wet or a dry charge
                drier, and clean all the oil out of the system, like a full retrofit but instead use prop
                wet charge
                if it doesnt work, you'll need a new drier probably do the whole thing again
                curiosity killed the cat
                  So it would just get cold really fast then the compressor will kick back and relax untill needed Aegean .
                    wet charge
                    so would I just get another r134 dryer and slap it on then fill my compressor with 5oz "I believe" and would I use pag oil ?
                      http://www.duracool.com/
                      also, look up R-290
                      and lastly an r-12 replacement:
                      http://www.freeze12.com/
                        also, look up R-290
                        I know about freeze12. I am going to use r134a or propane.
                          "Here comes the BOOM!" XD
                          1992 Accord EX-R Coupe [Mat Black] Sold
                          1992 Accord EX-R Coupe [Rosewood]
                            Using propane doesn't even sound safe. That just seems crazy.
                            93 CB7 SE Coupe
                            00 EJ6 Sedan
                            12 Pilot Touring
                            08 Altima Coupe V6 SE
                              Stop trying to whore posts with wise comments that have already ben stated above.
