I was thinking bout getting a h23 tranny but what tranny is better a h22 or h23 tranny to go with my g22
what tranny is better?
....G22?
The h22 tranny has shorter gears than the h23, f22 being the longest gears, h23 being in the middle and h22 being one of the shortest.
Are you looking for acceleration or top end speed?
h23 tranny = nice gears that are not to long and not to short. good for a dd that you still want to be able to dip in.
h22 tranny = super short gears for racing
I am doing a f23 swap and I am using a h23 tranny (m2s4)Last edited by thepowderblue; 08-12-2011, 05:49 PM.
The main difference between the h22 & h23 transmissions is the 5th gear. H23 is longer, so when cruising on the freeway you'll be at a lower rpm, which will help with highway fuel economy. Choose the H22 transmission if you want the fastest acceleration possible after 90-100mph, or whatever speed 4th gear tops out at. If fuel economy is your main concern then the f22 transmission would be best, as it has the longest gearing of all 3.
If you were planning to boost, the f22 transmission would be better as you would stay in boost longer. Otherwise NA motors will benefit from the H22/H23 transmission, if your goal is to cover a set distance in as short amount of time as possible, and fuel economy isn't a primary concern.Last edited by cloudasc; 08-14-2011, 12:33 AM.
Theres No h23a tranny that came LSD, u need to install an aftermaret one.
I already knew what z g22 was, just wondering why you did that motor...
From shortest to longest.
h22, h23, f22b1, f22.
if i can find a f22b1 for cheap i would get it, if not ill op for the h23, fun trans to match out f22a's to, but u havea g22, either way still a fun trans**Blk Housed Slut Crew Member #1**
