injectors difference f23/f22
    Alright i went and changed my f23a injectors in and took out the f22b1 injectors out...now i need to know if it was that change that gave me a small boost at high range rpms. now my car aint red lining till like 7000 rpms..
    would that give me a real boost like that..? i want to know if maybe i can swap a h22 intake manifold with fuel rail would it give me more power or its not possiable...
    The H and F series have the same fuel rail.
    More fuel does not equal more power... so swapping injectors won't do a thing for you.
    F23 injectors are OBD2. Is your F22B1 OBD1 or OBD2? (you're not giving very much detail as to what you're actually running... it's clearly not a stock CB7.) I believe both are 235cc anyway.
    What ECU are you running?
    I don't believe the H22 intake manifold is usable on an F22B1.
      Also all of the F23 injectors are the same 240cc flow rate as the rest of the F22A & B injectors. Difference being that all of the F23 injectors are high impedance. Where as the F22A & B injectors are all low impedance.
      If you saw a boost in power swapping back to your stock F22B1 240cc injectors. That difference would probably be that the high impedance 240cc F23 injectors wouldn't have worked as well with the resistor box in place.
      Only intake that will fit, with IAC mod, is the F23 IM. Adding larger injectors without the appropriate ECU or a tune will give you no added gains.
      MR Thread
      GhostAccord 2.4L Blog
      by Chappy, on Flickr
