Sometimes the car will start other times it won't. Any one know why?
starting problem
If your car was sitting in the heat for a little while and you went to go start it and it wouldn't start, then there is a possibility it could be your main relay. In order for you to start your car did you have to sit there and turn the key to the on position and back off continuously?
Here's a DIY for the main relay.
http://www.cb7tuner.com/vbb/showthre...ght=main+relay
If you have a CEL why don't you pull the code... it would help isolate the issue, instead of guessing.Originally posted by danyuulcosta View PostCan the main relay trigger the CEL? Cause my car is having issues starting and my CEL is on.
