well a buddy has a 95 cd7 f22b2. he has a cracked blocked. he picked up a f22a1 motor to replace the b2 motor. swapping heads isnt an option for him. he wants to use the whole a1 motor. what are some things he may need to change or replace to run the a1 motor in his cd7? i donated him my a6 exhaust mani for his a1. i noticed he may need a different down pipe to be able to use the a6 exhaust mani and would have to extended the wire for the o2 sensor. will the b2 dizzy work in the a1?
CD7 with F22a1
Your buddy needs to be careful if he is in an emmissions testing area, as the f22a1 was only found in our generation accords, and 92-96 preludes. From what I know, usually an engine being installed has to be newer then the chassis/frame of the vehicle its going into to be 100% legal. So unless that motor came out of a 95-96 prelude, he might not be allowed to use it.
