hey all, i slightly been tighting up the throttle cable and got a nicer responce under accelleration but my question is what exactly does the other cable do that traveles to the tranny? this is a 93 automatic ex. i also at the same time slightly been tighting this cable up to. i read in the chilton manuel that this cable should have a tiny bit of play. does it open a valve or something in the tranny? the main reason why im doing this to see if i can solve a tranny problem, i replaced the shift solenoid but unfortunatly didnt work. as a refresher whats going on is when you start to accellerate at a lower speed it wont shift into 3rd unless you take your foot off the gas pedal. but if you take off quickly it seems to shift correctly.....pretty messed up huh. the fluid is topped off and not crazy worn out looking and there are no blinking light. anyone else have this problem?
I don't do body work, and I know you can cut them out with a utility knife and a steady hand (watched it done nicely by a friend of mine), or a dremel and a cutoff wheel if your hand's not so steady)
Friends
