Help! Fuel Leak!!!
    Help! Fuel Leak!!!
    Hi!
    Well my problem is in the spot when the fuel line took on the fuel rail. I put the two(2) little spacers (one up and one down the fuel line), i clean everything really nice but still having this problem.
    any suggestion?
    THANKS!
    Did you fit new washers (spacers), if so did you make sure you took the old ones off?
    My 5.7 LS1 Holden Ute
      nop! im using the old ones thankyou i forgot that word (washers) LOL!
      maybe i need to buy new ones then!
        Where exactly is leaking? Are you saying its leaking from the 17mm nut that attaches the fuel line to the rail?
          YES! look this pic
            Ok that semi simple, either you put too many washers in, they are too thin, two on top and zero on bottom, vice versa, didnt tighten it all the way, or its not screwed on right. Oh yeah check the hole the the line slips over, make sure its not clogged.
              where can i get new crush washers at, dealer? I tried looking up the part number, no luck.
                Part number 36
                  thanks
                    thanks
                    I just realized the part number wasn't there....derp.
                    90428-PD6-003
                      It's best to use new ones. But, you could try annealing the washers if you are in a pinch.
                      http://www.motoiq.com/magazine_artic...r-washers.aspx
                      I believe you could do the same even if they are made of aluminum.
                      A&P-IA
