The following is text i found on a guide of h22a swap into a 93 accord .
"If your car came equipped with an internal coil then the jdm h22 distributor will plug right
in no problem. However, if your car had external coil then you will have to modify one plug.
The plug you will need to modify is the plug that went to the stock coil. There are is a yellow
and a yellow/black wire, splice those 2 wire together. The green wire is useless, dont worry
about it"
ok now help me understand this part "The plug you will need to modify is the plug that went to the stock coil. There is a yellow
and a yellow/black wire, splice those 2 wire together" what plug is it talking about? the one on the engine or the one coming out of the accord harness ?
am just stuck here..
about it"
