I have a 93 ex 4dr...and its been driving fine after i fixed it...now the spedometer falls all the way down then back up...never seen this before
Speedo Problem
i had that same problem and spent like 500 going to a machanic but finlay
got it to work by changing the vss ill see if i can find the thread ok.
here it is hope it help cus it helped me lol http://www.cb7tuner.com/vbb/showthre...ght=VSS+issuesOriginally posted by Ds060510 View PostI have a 93 ex 4dr...and its been driving fine after i fixed it...now the spedometer falls all the way down then back up...never seen this beforeTHEN
NOW
The ignitor could also be the culprit.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
The ignitor would cause the tach to go nuts, not the speedo.Originally posted by dj_ender View PostThe ignitor could also be the culprit.
The problem is your VSS, your wiring, or your cluster itself. Start with the VSS, as that's most commonly the part that fails.Originally posted by Krowned King View Postim trying to figure out why mine dont work at all i have just been using my gps but it works lol..
Yeah that was a bone head post, dunno what I was thinking. Op pull your cluster and look for damage like this:Originally posted by deevergote View PostThe ignitor would cause the tach to go nuts, not the speedo.
Yes there are 4 discolored spots in a vertical line in the center of the pic. Those are causing the tach, speedo, and lights to not work.Originally posted by deevergote View PostThe board looks burned to me right in the very center, to the right of the glare, on the other side of those two side-by-side solder points.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
