Ok so recently my check engine light turned on (most annoying light ever!) and after checking the code it came out to 12 (one fast blink then stop then 2 slow blinks, correct me if that's not 12) and after doing research It comes out to EGR Valve. I have cleaned it and erased the code but came back, then I got a different one and cleaned it and erased the code but still came back :-( anybody have any idea of what it could be ? Can this hurt my engine if I drive it for too long like that? ANY INFO MUCH APPRECIATED!! thank you
Check Engine Code 12?
Slow blinks are 10, short blinks are 1. So if you're getting two long and one short, that's code 21... however, that's a VTEC code... what engine and ECU are you running?
I would always assume that you could hurt your engine by driving with a CEL on. Something is not working right, which means your fuel probably isn't burning correctly. In time, that can foul your plugs and o2 sensor, clog your cat, and in extreme cases, cause buildup around your valves that may lead to them getting stuck. OR, you could be running lean, which could mean engine-destroying detonation.
That's what it sounds like to me, if the fast blink is coming first. I believe CEL codes always come with the slow blinks first.
I bet there's a decent pause between the fast one and the two slow ones...
1 is o2 sensor, and 20 is what... electrical load detector (had to look that one up).
In a brief search, it seems that the ELD is in the under-dash fusebox... but that's all I've come up with. I never had an issue with that myself.
Well which one is it exactly?Originally posted by ErMMaC View PostOk then it should be one long blink and 2 short, if that's the correct way to put it, and it's a stock f22
This is the way you described it in the beginning, 1 short flash then a pause then 2 long flashes. That means that there are two codes, 1 & 20.
Or is it that you actually saw 1 long flash + 2 short flashes = code 12?
You don't change the CEL flashed to fit what you think is the issue, you read the codes and fix the issues given.
1long flash+ 2short, sorry I described it wrong in the begginingOriginally posted by GhostAccord View PostWell which one is it exactly?
The "pause" I stated is too insuffiecient to be a second codeLast edited by ErMMaC; 09-30-2011, 11:59 AM.
Code 12 is for EGR. You could have a bad EGR valve, a leaking vacuum hose, bad EGR lift sensor, or the sensor in the "black box" on the firewall. All the light means is that the ECU is not seeing the EGR lift when it tells it to.Originally posted by Junior SmurffNevermind guys, google search works wonders!
I don't have road rage, my car just goes faster than yours!
Accords are for winners. And Grandmothers. But mostly winners.
I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
Originally posted by ErMMaC View PostCan anyone explain or show me a picture of the EGR valve location?
The little item in the lower left corner, under the throttle body, with the metal clip on it is the EGR valve. It has a vacuum line and a plug on it.Last edited by dj_ender; 10-02-2011, 11:53 PM.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
